Old 5-Jan-2014, 6:46 AM   #2
The Current Tv Channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Tv channels in All 3 Bands.
Recommend install a All Channel Antenna.
Also.
WVTM-DT , REAL VHF high band channel 13 NBC , is weak signal strength at 19 NM(dB) , has 2 Edge Path Obstructions and is 48.5 miles distant.
VHF high band channels benefit from extra help to have reliable reception with these less then good reception conditions.
Install antenna above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception , North East , East , South East , South.
Recommend install a http://www.antennacraft.net , HD1200 All Channel Antenna aimed at about 72 degree magnetic compass direction.
Install a RCA , TVPRAMP1R preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing , Blocking , Reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Digital Tuners Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's/Tuners will Automatic channel scan for cable tv channels.
Go into the Tv / Tuner , Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for , ATSC-Digital Broadcast TV Channels.
Last edited by teleview; 6-Jan-2014 at 3:16 AM. Reason: Clarify information and typos.
