Old 5-Jan-2014, 5:15 AM   #5
Install the DB8e antenna aimed at about 11 degree magnetic compass direction.
Install a RCA TVPRAMP1R preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Here are some above the peak of the roof antenna mounts.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
http://www.amazon.com.
http://www.solidsignal.com.
Absorbing , Blocking , Reception.
Multi-Path Reflecting Tv signals Bouncing All Around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 5-Jan-2014 at 7:00 AM. Reason: Clarify information and typos.
