Old 5-Jan-2014, 4:52 AM   #5
wireguy2014
Thanks for the feedback on the preamp, Ground.
I'll see how the tuners do with just the preamp before looking into a line amp if necessary.
I would avoid the CM-7777 and PA-18 for fear of overloading. They are intended for weak signal applications. The TVPRAMP1R is far more tolerant of strong signal inputs. I generally warn against the use of two or more amplifiers, though in a few cases, have seen good results. http://forum.tvfool.com/showthread.php?t=13659
wireguy2014 is offline   Reply With Quote
