I'm a bit concerned that the aluminum ladder and metal flashing at the edge of the roof may be affecting the tuning of the antenna...
Perhaps you have some pipe, tube or similar item that can serve as a mast? If possible, try to test with the antenna 3' or more from metal except for a tube or mast running through the rear clamp.
