Old 5-Jan-2014, 3:53 AM   #3
You can also put the , HDTVi in the the attic and connect to the coax system.
You can install a , http://www.antennacraft.net , HBU11 antenna in the the attic.
Here is how to aim indoor and outdoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If better reception is required , move the HBU11 antenna to Above the Peak of the Roof.
If any type or kind of cable delivered service is active , be it , cable internet service , cable tv service , cable phone service.
The cable delivered service Must Be On A Separate Coax.
Not connected to the antenna system coaxes.
