Even so , you should be receiving more Tv channels.
Maybe the CS2V has Defective Coupler that couples the , UHF loops / VHF dipole rods.
To prove reception.
I recommend install a NEW ANT751 antenna.
Connect a NEW Continues length of coax to the New ANT751 matching transformer (balun).
Run the New Continues length of coax , through a open door or window , direct to 1 Tv.
The Digital Tv Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast TV Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
The Digital TV Must Channel Scan for the , ATSC-Digital Broadcast TV Stations/Channels.
Reason: Clarify information and typos.
