Old 4-Jan-2014, 9:10 PM   #8
Use a REAL and Actual magnetic compass to aim antenna.
Reason: A magnetic compass is the Real and Actual way to Know the directions of , North , East , South , West.
Cell phone compass and etc. , are not reliable.
The Federal Antenna Law over rules all , Hoa's , etc. .
Hoas's and etc. , are well aware of the Federal Antenna Law and some Hoa's and etc. , are thinking that you are not aware of the Federal Antenna Law and even if you are aware of the Federal Antenna Law that you will not understand your rights and you will believe what the Hoa and etc. tells you that you can and can not do.
Some Hoa's and etc. will twist the wording of the law.
The Federal Antenna Law says Yes you can install a Tv antenna of any size outside above the roof , in and of , such a manner so as to have Reliable Reception.
http://www.fcc.gov/mb/facts/otard.html.
The Current Tv Channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
The Tvfool channel list shows the.
-->Real Channels that are being Transmitted and Received at your reception location.<--
And shows the , virtual numbers.
Last edited by teleview; 5-Jan-2014 at 7:10 AM. Reason: Clarify information and typos.
