Old 4-Jan-2014, 8:40 AM   #4
StephanieS
Hi Mikenh,
If RF 8 weren't in hi-vhf, this would be so much easier!
I also agree with GroundUrMast and Stereocraig regarding attic installations. With the signals you want, the only way you will have any success is with an outdoor mounting of the antenna. An attic installation will not net you any of your desired weak signals.
That said, with your desire to get real channels (RF) 10, 23 and 38 there are some possibilities. First, real channel 23 WPFO (FOX) is extremely weak. Reliable reception is going to require you having exceptional luck.
RF 10 and RF 38 on the other hand provide some better opportunities. RF 38 (CBS) ought to be pretty easy actually, for that see below.
The ANT751 while a nice little suburban antenna, with it you ought to see your line of sight signals while orientated to magnetic 83. The weak red shaded signals aren't what the ANT751 was built for even if mounted outdoors.
A Winegard 7698P mounted outdoors above your roof and clear of obstructions to magnetic 84 ought to receive ABC, NBC, CBS, CW and MyNetwork. I would not suggest a preamp in consideration for this antenna. NBC and ABC are putting a very good signal on you. A preamp would risk overloading your receiver.
PBS WCBB RF 10 is weak as well. At heading 84 you'll be within the beam of Winegard to know if you'll have reliable reception. If not reliable see below.
For alternate PBS service in the event of WCBB not decoding, I may add an Antennacraft Y10-7-13 (high vhf only antenna) as a secondary antenna pointing to magnetic 208. This would be for service from New Hampshire Public Television's WENH RF 11. If availing this option, I might add a RCA TVPRAMP1R on this antenna for best chance of reception. Make sure to connect the Y10-7-13 coax to the dedicated VHF input on the preamp. WMUR ABC RF 9 would be a signal to watch if it makes it to decoding levels.
If you just decide upon the Winegard 7698P orientated to magnetic 84, this is pretty straight forward with one coax coming off the roof.
If you add the Y10-7-13 mounted below (at least 4' spacing on the same pole) the 7698P, you'll have two coaxes running indoors feeding into a A/B switch. At the end of the Y10-7-13 coax coming off preamp install preamp power supply. A/B Switch is found here: http://www.homedepot.com/p/GE-A-B-Sw..._src=17588969#
It's all about if you want to "be done with it" or you want to test and refine until you get most of the signals you are seeking. When you are in these weak signal areas with different paths, sometimes you have to get creative and settle for what you can get.
Good luck!
