Old 4-Jan-2014, 8:10 AM   #2
To receive the Digital Broadcast Tv Stations/Channels down the channel list , NBC , ABC , CBS , down to and including ,
WDSI-DT REAL UHF Channel 40 , virtual number (61.1) , FOX.
Is Very Weak Signal Strength and has 2 Edge Path obstructions.
Recommend step up to the Big Winegard HD7698P antenna.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North , East North , West , South West.
Install the HD7698P antenna aimed at about 2 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
Install a RCA , TVPRAMP1R preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Here are some Strong and Sturdy antenna mounts.
Use the , ronard(4560) eave antenna mount.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box , or , buy from , http://www.ronard.com.
Last edited by teleview; 4-Jan-2014 at 9:30 PM. Reason: Clarify information and typos.
