Old 4-Jan-2014, 1:51 AM   #1
good1dave
Getting ready to cut the cord! Antenna Selection Help...
Here is my TV Fool Report:
http://www.tvfool.com/?option=com_wr...46aee0961df39d
I am most interested in getting NBC, ABC, & CBS....anything else is just icing on the cake. I was able to pick up 13 channels with a crude antenna I made and stuck on top of my TV. Could get CBS this way (kinda flakey though), and no NBC or ABC. Lots of other channels came in great (FOX, PBS, the CW, etc) - and most were high def.
Unfortunately it will be an attic install, cannot convince my wife otherwise. I am trying to stick with equipment that is Amazon Prime stuff in case something doesn't work out (easy returns).
I'm thinking about this model antenna:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
I'm thinking about this mount:
http://www.amazon.com/Antennas-Direc.../ref=pd_cp_e_3
We have 5 TVs, eventually I want to hook them all up. This is a small-ish house (1600 sq ft), so no really long cable runs (most shouldn't be more than 20-30 ft the way it's laid out). I'm I bit confused on what I might need to split up the signal (once I get a solid lock on the stations). Splitters, pre-amps, etc.....I'm I bit lost here. I can run the cable pretty much however is best, if it all needs to come from one splitter or whatever - I can make it happen.
Thanks for the advise!
good1dave is offline   Reply With Quote
