Old 4-Jan-2014, 12:56 AM   #2
The Main group of Digital Broadcast Tv Station Transmitters are to the , East.
In/at a , East , South East , facing window , put a Terk HDTVi antenna , (not HDTVa) , aimed at about 100 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , www.kyes.com/antenna/pointing/pointing.html
The Digital Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC - Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan to cable Tv channels.
DO NOT channels scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ Air Channels ~.
Scan for the , ATSC - Digital Broadcast Tv Channels.
