Old 4-Jan-2014, 12:18 AM   #12
StephanieS
On the same pole, make sure you mount them 4 to 5' apart if possible.
If you have them "on top" of each other, that isn't ideal and can cause the antenna to not perform as well. Four to five feet spacing ought to be fine on the pole.
Many mount multiple antennas on one pole.
See my set up before I did some wire adjusting last summer. The smaller antenna (ANT751) serves as a backup and if KXLY is being flaky on the 91xg, the ANT751 will likely have a solid lock on it.
Both antennas have separate leads of coax coming inside. I switch between them via an A/B switch.
My set up:
Originally Posted by matter View Post
I will. The 4221 was a Christmas gift so I may try to stick it out depending on my options. So no interferance concerns of the antennas being too close together?
