Old 3-Jan-2014, 11:05 PM   #8
StephanieS
While at heading 260 did you do a rescan on your TV? In the digital world, when you reorientate your antenna towards weak signals rescanning is a good idea.
The fact you see KSPS' translator while not pointing at it gives me a hint that the other Wenatchee translators might be receivable with a stronger UHF antenna as ADTech suggested.
It sounds though like Tri-Cities is the priority? If so, additionally order the Antennas Direct 91xg is my recommendation. You may find KEPR decodes as well working in tandem with the preamp. The 91xg will give you the best chance at UHF reception of Tri-Cities.
Originally Posted by matter View Post
They say every can of worms has a lid somewhere, but I wonder...
So I tried turning towards 260 and was a little disappointed but I understand now that I am getting many of the channels from there even when I am aimed south. So I just turned to about 160 and things look pretty good for no preamp. So I think I will order a RCA TVPRAMP1R and a Antennacraft Y10713 and see where that leaves me. Do I need to worry about distance between the two antennas?
