Smart - I didn't think to try the 751 as a VHF only antenna. Since I have that on hand I'll try that first.
Follow up questions:
1. I have the RCA Pre-amp power supply in the attic where it can remain protected from the weather. The installation is somewhat like this: Antenna -> Pre-amp -> 20ft of RG6 -> pre-amp power injector -> 30 ft of RG6 to splitter -> out to TVs (3 at this time, want 4). Is there any problem with the way I have installed the power injector? (All install diagrams I have seen want the injector at the TV)
2. You recommend I remove the dist. amp - I'll try this after the changes on the roof and report back. But in advance... being curious... can a decent antenna drive 4 TVs w/o a distribution amp?
tia, mike
