I'd suggest keeping both panels aligned in parallel and splitting the difference between the two southeast headings for your aiming direction for your initial effort. The antenna receives best when the panels are working together and the spread between the two headings is less than the -3 dB beamwidth of the DB8e on the channels of interest.
The nearest NBC affiliate to you is in Plattsburg and is out of range.
