Old 2-Jan-2014, 8:43 AM   #3
If you have a tall straight tree , the tall straight tree can be used as a Tv antenna tower.
The idea is to get the antenna up high and avoid or reduce the other trees that will disrupt reception in the directions of reception.
http://www.ronard.com/tree_adjust.html.
I recommend start with a Test antenna , a ANT751 aka ANT751R Above the Peak of the Roof Up High , in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North East at 12 degree magnetic compass direction , counter clock wise , to South West to 237 degree magnetic compass direction.
The Main group of Digital Broadcast Tv Stations/Channels are at 308~311 degree magnetic compass direction.
Aim the ANT751 antenna at about 308~311 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ DTV Channels ~ Air Channels in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ Air Channels ~.
Scan for channels.
Home Depot and Lowes can have the ANT751 in stock in the store no matter what the Home Depot and Lowes web sites say.
Some more places to buy antennas and etc. .
http://www.amazon.com.
http://www.solidsignal.com.
www.ronard.com
Last edited by teleview; 5-Jan-2014 at 8:08 AM. Reason: Clarify information and typos.
