Your reception location has Digital Broadcast Tv Stations/Channels on All 3 channel bands.
Recommend install a All channel antenna.
Install a ,
www.channelmasterstore.com , CM5018 antenna aimed at about 334 degree magnetic compass direction.
Install the CM5018 antenna above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in All directions.
-----------[/QUOTE]
Ok, sounds like the CM5018 is a good choice. I have no problem focusing on the Chicago stations. However, I was just wondering if there any other ideas or options out there?
AD Tech recommends going with the DB 8. I really dont know the difference, just looking for help with the pros and cons.
Thanks.
