Old 1-Jan-2014, 11:36 PM   #4
-->As Always<-- the Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC - Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ Air Channels ~.
Scan for channels.
Your reception location has Digital Broadcast Tv Stations/Channels on All 3 channel bands.
Recommend install a All channel antenna.
Install a , www.channelmasterstore.com , CM5018 antenna aimed at about 334 degree magnetic compass direction.
Install the CM5018 antenna above the peak of the roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in All directions.
www.ronard.com/909911.html
www.ronard.com/34424560.html
Use the , ronard(4560) eave antenna mount.
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
A antenna system amplifier is not required.
Buy the , HFS-2D , splitter at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
Some and not all Negative Effects are ,
Absorbing , Blocking , Reception.
Multi-Path Reflecting Tv signals bouncing all around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 2-Jan-2014 at 3:38 AM. Reason: Clarify information and typos.
