Thanks GroundUrMast. What if I install the ANT-751 so it sits below the top of the chimney, say 2' below the flue opening? That would place the antenna 14' above ground. Would there be a problem with the antenna facing away from the chimney, towards the south, in terms of the bricks reflecting signal into the back side of the antenna?
