Did you use the setup menu of your tuner to change the tuner from cable mode to 'antenna' or 'air'? Did you then perform a full channel scan? How old is your TV? Does it have an ATSC capable tuner?
Even with "a piece of junk set top antenna" you should expect to see quite a number of channels.
