Old 1-Jan-2014, 8:45 AM   #4
Just aim (point the narrow front end) due west as a start. The ANT-751R is pretty forgiving... But try adjusting left and right in 10° steps to see the effect on reliable reception of the stations most important to you. Running a scan each time you make an adjustment... Use the add scan function if your TV has it.
