Thread: Indoor antenna
Old 31-Dec-2013, 4:47 PM   #2
Is Important to have a tvfool report.
Using the Exact address to make the report.
For the best possible recommendations of antennas and etc. .
Make the antenna height in the tvfool report 25 feet above ground.
25 feet antenna height above ground is a reference Tv antenna height above ground that provides a good starting evaluation of of what is receivable.
To make a tvfool report go to the tvfool home page and click on , >>Start MAPS<< , enter the Exact address and make the antenna height in the report 25 feet above ground.
If the Exact address does not work to make the tvfool report.
Then enter in the zip code only , and then on the tvfool map move the pointer to you Exact reception location and make the report with the antenna height 25 feet above ground.
If the zip code does not work then use some other address around the area and then move the pointer to your Exact location of reception.
As you may or may not have noticed reading the other question askers threads and posts , accurate information is Important for evaluation of reception and the best antennas to use and why.
Obtaining reliable reception is important.
It is about Reception First , and then the hd high definition picture.
Not HI Definition picture first and then reception.
Make the report and post it so a recommendation can be made for reception.
Last edited by teleview; 1-Jan-2014 at 2:28 AM. Reason: Clarify information and typos.
