TVFool Antenna height accuracy?
Still striving for the best signals possible. In review I ran Antenna Fool at every 5' on my tower from the current 60', up and then down. Yes there was improvement at like 100' or something, but that is not happening.
What I see is that for my Kansas City stations they basically get better the lower I go and the sweet spot overall for my weaker stations is 25' high. (It does tank at 20') My trees are higher than this. I am at the outer fringe of these signals and am one of the higher points around. After my hill the signals pretty much drop off. Several key stations have about a 2NMdb increase a few stronger ones have a -2, but they have plenty to give.
But should I not be above the tree line? My neighborhood is not heavy with trees, but there is that point when climbing the tower that you clearly transition and go from calm to breezy. I know this change in signal strength can be true, but it flies in the face of "conventional wisdom".
Thanks
