Old 31-Dec-2013, 5:27 AM   #3
The Current Broadcast Tv stations/channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF channels 14 thru 51.
Your location has receivable Broadcast Tv stations/channels in All 3 Tv bands.
All of the Tv Networks are received with 1 All Channel antenna aimed in 1 direction.
I recommend install a , http://www.antennacraft.net , HD850 All channel antenna , or , http://www.channelmasterstore.com , CM5018 All channel antenna aimed at about 80 degree magnetic compass direction.
I recommend install the antenna Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North East , East , North West , West , South West.
Here are some above the roof antenna antenna mounts.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.solidsignal.com , buy typing , ronard(x) , in the solidsignal search box , or , buy from , http://www.ronard.com.
http://www.antennacraft.net.
http://www.channelmasterstore.com.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.hollandelectronics.com
Install a RCA , TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Last edited by teleview; 1-Jan-2014 at 7:01 PM. Reason: Clarify information and typos.
