Thread: Best Antenna
Old 31-Dec-2013, 3:25 AM   #3
For reception of ->Many<- Digital Broadcast Tv stations/channels.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East , West South West.
Install a Antennas Direct DB8e antenna.
The DB8e antenna has , 2 , 4 bay bowtie antenna panels that can be aimed in any direction.
Aim 1 panel at about 90 degree magnetic compass direction.
Aim the 2nd panel at about 281 Degree magnetic compass direction.
Also install a Antenna Craft , Y10-7-13 antenna aimed at about 253 degree magnetic compass direction.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
The DB8e UHF antenna and the Y10-7-13 VHF high band antenna are connected together with a UVSJ=UHF/VHF antennas combiner.
The DB8e is connected to the UHF connection of the combiner.
The Y10-7-13 is connected to the VHF connection of the combiner.
The remaining connection of the combiner goes to the 1 Tv location or 2 way splitter.
This is the Combiner , EU385CF-1s , at http://www.solidsignal.com.
http://www.antennacraft.net.
http://www.amazon.com.
Looking at the Digital Broadcast Tvfool Current Plus Pending Applications Included Radar Plot and Channel List.
To the West South West.
You will be looking for reception of the weak signal strength , WKFK-LD VHF high band channel 13 , http://en.wikipedia.org/wiki/WKFK-LD.
And WMAH-TV , PBS.
And WXXV-TV , FOX.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
