If I use an HLSJ, will that allow my UHF to pass through over the Hi input.
Yes.
Sounds like these HLSJ's are only for VHF-Ho and VHF-Lo joins.
Nope. The "High" port passes everything above the crossover frequency which includes, of course, UHF frequencies.
Convert everything to 75 ohm coax/F-connectors using matching transformers, then do whatever is necessary.
