Thanks for the fast reply.
RE: VHF-Hi (7-13).
I get channel 12 (WHYY-TV) in no problem with the 4bay antenna.
I assume the signal combiner would need to accept "vhf-hi/uhf" on one input, and "vhf-lo" on the other. Or some combination of combiners to achieve the equivalent.
I wonder if I can build a 1/2 or 1/4 wave antenna just for Channel 6. If there is a more "turn-key solution", off-the-shelf, I will consider that as well.
