Old 30-Dec-2013, 6:40 PM   #1
milton
Combine UHF and VHF-Lo. DIY 4bay attic mount design
Background Info
I am considering canceling COMCA$T for CATV service. Roku and AppleTV with OTA local stations in HD will replace.
I built a home-made 4-bay antenna (cat whisker style) with reflector and mounted it in the attic.
Construction: pvc vertical spine, #10 copper wire for whiskers and phase lines, aluminum foil over cardboard for reflector.
Configuration: 10" whisker length, 9.5" spacing between bays, 5" space between reflector and array.
All desired stations are 25miles away at 211 degrees, so antenna shall remain in a fixed position.
http://www.tvfool.com/?option=com_wr...46ae9aa61c19b3
Current Status
I am able to receive all desired stations (UHF) including the one VHF-Lo station (WPVI - 85Mhz) when the antenna is connected directly to my TV over a 15' cable run. However the VHF-Lo station does pixelate from time-to-time.
I added a splitter resulting in a 15' and 40' run. TV's at the end of each. This caused me to lose the VHF-lo station and several of the UHF stations became weaker (pixelation). I added an amp that I had laying around (Leviton 48210-VA), before the splitter in the attic. This gave me back all of the UHF stations but the VHF-Lo station is still lost. FM-trap off worked best on the amp. I understand this amp is not meant to be used as an antenna pre-amp, and I plan to purchase the correct amp for my application.
Goal
I want to pull in that one VHF-Lo station along with the UHF stations, over a single coax cable in order to drive the rest of the TVs in my home.
The first step will be the following:
Antenna--->PreAmp---->split(A,B)
split(A)--->15' Coax ----> TV
split(B)---> 40' Coax ----> TV.
The final configuration will be the following:
split(B)---> 40' Coax ----> DistributionAmp ---> 3 20' coax homeruns to 3 TVs.
Questions
1) I understand the 4-bay configuration is a UHF antenna and not designed to receive VHF-Lo. What type of antenna design should I use?
2) Assuming I build that VHF-Lo antenna, what is the best way to merge the signal with the UHF signal from the current 4-bay antenna? before or after the 300/70 ohm balun? And what device should I purchase (brand)?
3) The attic gets very hot in the summer. Do these preAmps handle that kind of heat? If so, what type/brand should I purchase (note my electrical outlet is also in the attic and subject to heat)? Or should I pull the coax line into an area that is room temperature?
4) Is there a better overall approach to meet the goal I stated above? I am ok with spending the $ for an antenna and solid preAmp considering it will drop my monthly cable bill by $120.
Thanks
milton is offline   Reply With Quote
