Old 30-Dec-2013, 5:46 AM   #2
The Receivable Digital Broadcast Tv stations/channels are Very Weak Signal Strength at your location.
The strongest signal strengths over all.
Are the group of Tv stations are to the , East North East at about 74 degree magnetic compass direction.
The Tv transmitters are on , Mountain Top.
Here are the Digital Broadcast Tv Stations/Channels that are on , Mountain Top.
WBRE-DT , REAL VHF high band channel 11 , NBC.
WYOU-DT , REAL VHF high band channel 13 , CBS.
WNEP-TV , REAL UHF band channel 50 , ABC and digital sub channel Antenna Tv.
WVIA-TV , REAL UHF band channel 41 , PBS channels.
WOLF-DT , REAL UHF band channel 47 , FOX and digital sub channels The CW and MyNetwork.
The Tv signal strengths are Weak Signal Strength at your reception location.
BIG Antennas Receive more signal , small antennas receive less signal.
Install a BIG Antenna.
Install a , http://www.antennacraft.net , HBU55 antenna aimed at about 74 degree magnetic compass direction.
There is also the group of Digital Broadcast Tv stations/channels to the , South South East , Harrisburg Area.
Install the HBU55 antenna above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East North East and South South East.
Buy the ronard antenna mounts at , http://www.solidsignal.com , or , http://www.ronard.com.
Install a , http://www.channelmasterstore.com. CM7778 preamplifier.
Buy the HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Here are some places to buy antennas ands etc. .
http://www.antennacraft.net.
http://www.solidsignal.com.
http://www.amazon.com.
The Tv/s Must Channel Scan for the , OTA=Over The Air Digital Broadcast Tv stations/channels , often named the ~ Antenna Channels ~ DTV Channels ~ Air Channels in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the TV Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ Air Channels ~.
Scan for channels.
Some and not all Negative Effects are ,
Absorbing and Blocking Reception.
Multi-Path Reflecting Tv signals Bouncing All Around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
You can also Test Reception of the , South South East group of Digital Broadcast Tv station/channels by aiming the HBU55 antenna at about 176 degree magnetic compass direction.
Scan for channels.
Also take note that Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Last edited by teleview; 3-Jan-2014 at 5:15 PM. Reason: Clarify information and typos.
