300' is not too far to consider running a drop off of your system if there's no problem with right of way. For a 300' run, I'd use RG-11. A CM-3410 would be enough amplifier to drive that distance. (Running cable between two locations served by separate electrical services can be tricky if there is a significant difference in ground potential between the locations. Proper grounding methods need to be used at both locations.)
However, I would make every effort to make the HD8200 work, including the suggestions already offered by teleview, and, if possible, alternate mounting location/elevation (avoid the trees).
