Old 28-Dec-2013, 5:39 AM   #3
Based on your description of the trees, the HBU-44 is certainly not excessive. I'm in the same market as you, with a slightly better TVFR and have concluded that you can't install too big an antenna.
If you would like to consider a premium solution, an Antennas Direct DB8e + Antennacraft Y10713 + RCA TVPRAMP1R preamplifier would be my suggestion. This gives you the ability to tweak the aim of the UHF and H-VHF antennas independently while giving a bit more gain than a large combo antenna.
