Old 25-Jan-2010, 2:17 PM   #1
Armando
Fixing channel interference
Hello, I am trying to see if there is a way I can do something so multi-path interference doesn't affect stations I am trying to tune in to. All of the channels are in the green zone and within 13 miles and should come in fine but some stations cut out too often. I am using the tuner from a Vizio set and I have tried rabbit ears, old attic antenna, and a Phillips MANT940 on rooftop. Am I out of luck with multi-path affecting me or is there a solution?
http://www.tvfool.com/?option=com_wr...c723e3d3a607cc
Armando is offline   Reply With Quote
