Old 27-Dec-2013, 11:46 PM   #1
couchsachraga
Best antenna for my situation question...
First off, a THANK YOU to the numerous folks here who share their knowledge generously and freely. I've learned a lot by reading through many threads.
Unfortunately I've also realized I am not confident I've learned enough yet to be able to figure out the best way forward for my situation.
We've never had a TV, and have ordered one for next week (TV free for the 15 years I've been out of college has been nice… but with young kids just using a computer screen doesn't quite cut it ).
My goal is to get a few local stations, particularly the excellent Vermont PBS station (which unfortunately is in the "wrong" direction compared to just about everything else) to complement the content we view over the internet / purchase via iTunes.
Here is the site analysis:
http://www.tvfool.com/?option=com_wr...46ae873f426332
My instinct is to use a directional antenna without a tremendous amount of gain (at least on VHF (Vermont PBS)) and point it southish (towards numerous other stations I could likely get with an outside antenna on the roof), and hope that the stronger VHF PBS station still comes through OK. It appears I'll need an antenna capable of UHF as well as high VHF (the closest low VHF is 49 miles away, and is repeated on a UHF frequency 4 miles away…). What reviews and information I have found so far leads me to the either the CM2016 - a bit of gain at UHF frequencies, multi-directional at VHF (hi) frequencies. I'm assuming that if a "green" (strong) channel such as Vermont PBS would normally be receivable with an INDOOR antenna that an outdoor multi-directional one would be OK? OR the ClearStream 2V (same concept…essentially 2 antennas in one, though rather than rabbit ears it is a dipole). What others should I consider, and should I cross either of these off the list?
I (or rather my wife) would prefer NOT to have a huge yagi on the roof. I'm a ham and there may be a few antennas around already… ).(no HF directionals yet though….just a UHF / VHF vertical and an 80m sky wire (loop) for the curious), so a 13'+ yagi beam with a rotor is out (for now).
This will feed 1 TV, and I'm hoping to keep the coax run under 50' (on a side note, I can't believe everyone uses RG6. The loss in that stuff is unreal at UHF frequencies! but it appears to be the "standard"). (look up attenuation of LMR600 and compare to RG6…).
I would be grateful for any thoughts, opinions, and recommendations on which antenna to purchase, and what direction to point it (in general… I am very comfortable pointing it in the correct direction as long as I know which tower I'm aiming for ).
couchsachraga is offline   Reply With Quote
