Old 23-Dec-2013, 4:42 PM   #4
For improved reception.
Above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , All Directions.
Install a ,
http://www.channelmasterstore.com , CM5016 All channel antenna.
Or a , http://www.antennacraft.net , C290.
Or a ,
HD850 ,
Aim the antenna at about 200 degree magnetic compass direction.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are ,
Absorbing , Blocking , Reception.
Multi-Path Reflecting Tv signal bouncing all around.
The Best Practice is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 25-Dec-2013 at 5:38 PM. Reason: Clarify information and typos.
