Old 21-Dec-2013, 9:48 AM   #6
I agree with the suggestions of the DB8e and Y10713. However, you can save money and part count by using an RCA TVPRAMP1R which has the UVSJ built in. (It has separate inputs for the UHF and VHF antennas.)
If you fail to get reliable reception from both directions using one antenna it won't be due to the antenna choice, but rather the modest to weak signal levels and any obstructions (if present). You would still have the option to add to the system if needed/desired. http://forum.tvfool.com/showthread.php?t=2882
