Old 21-Dec-2013, 6:39 AM   #5
Looking at the tvfool , Digital Broadcast Tv Current Plus Pending Applications Included radar report and channel list.
For reception of the UHF stations of both directions , down the channel list to and including KQFX-LD UHF channel 22 , FOX.
Install 1 Antennas Direct DB8e UHF antenna. One panel aimed at about 103 degree magnetic compass and the other panel aimed at about 272 degree magnetic compass direction.
The DB8e has 2 , 4 bay Bowtie antenna panels that can be aimed any direction.
To add KOMU-DT VHF high band channel 8 , NBC and CW.
Install a Antenna Craft , Y10-7-13 antenna aimed at about 94 degree magnetic compass direction.
IMPORTANT --> Use All New , coax , couplers , connections , connectors , etc. outside.
IMPORTANT --> Use RG-6 coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
A Tv antenna rotator is not required.
Combine DB8e antenna and Y10-7-13 antenna with a EU385CF-1s , UVSJ = UHF/VHF , combiner from , http://www.solidsignal.com.
Connect the DB8e antenna to the UHF connection of the combiner.
Connect the Y10-7-13 antenna to the VHF connection of the combiner.
Connect a Channel Master CM7778 preamplifier to the remaining connection of the combiner so that both antennas are amplified at the same time.
For one Tv connected use No splitter.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Install the Y10-7-13 antenna below the DB8e antenna on the same mast.
If you can , separate the antennas buy about 3 feet.
http://www.amazon.com.
Here is the way that I find out what Networks are on the Tv stations , and more Practical and Useful information.
In the Google or Yahoo search box type in variations of the Tv stations call sign.
Examples , komu , komu tv , komu-tv , komu dt , komu-dt and so forth.
2 Practical and Useful web sites (there are also other web sites) found are , wikipedia and http://www.rabbitears.info
http://en.wikipedia.org/wiki/KOMU-TV.
www.en.wikipedia.org/wiki/KQFX-LP .
_________________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Last edited by teleview; 27-Dec-2013 at 3:28 PM. Reason: Clarify information and typos.
