Old 21-Dec-2013, 4:22 AM   #4
whistler0
Ok, the FM trap is $5 so I ordered that, and we will see if that helps. Does it need to be out with the antenna or can I put it inside by the tv? I don't have an amplifier in the system.
I'll try moving the antenna around after that, along with the double rescan.
Fabricating is fine, I was just hoping to not need multiple antennas. But I will study up on those links as well just in case.
Thanks for the advice!
whistler0 is offline   Reply With Quote
