Old 20-Dec-2013, 7:24 PM   #3
Does reception improve with , Antenna aiming changes , mounting heights changes , antenna location changes.
Aim the antenna at about 65 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointong/pointing.html.
Also.
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting signal bouncing all around.
Install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 21-Dec-2013 at 4:52 PM. Reason: Clarify information and typos.
