Old 20-Dec-2013, 1:47 AM   #4
Yes aim the ANT751 antenna at about 249 degree magnetic compass direction.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna aim can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and , some Digital Tv's also have a , Signal Quality Meter.
The meter/s are used to help get the best reception.
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
If having reception issues that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic.
Then move the ANT751 antenna to above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West , West , North West , North East , East.
The local Tv stations are strong to moderate signal strength at your location.
A antenna system amplifier should not required for , 1 , 2 , 3 , Tv's connected.
Last edited by teleview; 21-Dec-2013 at 3:25 AM. Reason: Clarify information and typos.
