Old 19-Dec-2013, 9:15 PM   #3
The reception is very strong signal strength at your location.
Do not use any type or kind of amplified antenna or add on antenna system amplifier.
A simple indoor , non amplified , antenna such as a , Terk HDTVi antenna ( not HDTVa ) antenna , aimed at about 200 degree magnetic compass direction will receive , Many , Digital Broadcast Tv stations/channels.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
The Tv Must Channel Scan for , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ , in the Digital Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Last edited by teleview; 20-Dec-2013 at 6:08 AM. Reason: Clarify information and typos.
