Old 19-Dec-2013, 8:09 PM   #2
You have a great report, lot's of strong signals.
You may find a small indoor antenna is enough. (I'm thinking of the Terk HDTVi).
However, I would avoid the possible frustration of indoor reception problems and mount outdoors, clear of obstructions.
Antennas such as the RCA ANT-751, Antennacraft HBU-11, HBU-22 or HBU-33, Antennas Direct C2-V and Channel Master CM2016 fit your application. Simply aim toward the west.
You should not need any sort of amplification unless you are going to have many TVs connected.
If the signal from K05MD is of interest to you, add an Antennacraft Y526 pointing SSE to the system. You would need a HLSJ to combine the two antennas.
http://www.antennacraft.net/Antennas/AntennasVHF.html
http://www.solidsignal.com/pview.asp...-%28zhlsj-1%29
