Old 18-Dec-2013, 6:53 PM   #6
The DVR or Digital TV , Must Channel Scan for , OTA=Over The Air , Digital Broadcast Tv stations/channels.
The , ATSC , aka = also known as , 8VSB , Broadcast Tv Channels.
Some Digital DVR's with built in tuner will Automatic channel scan for cable tv channels.
Go into the , DVR Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Go into the , Digital Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Also Do Not channel scan for Analog channels only.
The signal strength reception is strong at your location.
Recommend Do Not use a amplified antenna.
Recommend Do Not use a add on external antenna system amplifier.
A Simple Non amplified indoor type antenna should receive Many Digital Broadcast Tv stations/channels.
A Simple Indoor type antenna that has no , so called 'fine tuning' control knob/s , or other fancy gizmos that are designed to separate you from your money.
A Plain and Simple indoor type antenna is the , Terk HDTVi (not HDTVa) indoor antenna.
For Best Reception have the HDTVi antenna in/at a window or patio/balcony door window that faces , East/North , East , South East.
Aim the HDTVi antenna at about , 96 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass to aim HDTVi antenna.
If a long length of coax is required to connect the HDTVi Antenna to DVR/TV, and the long length so coax runs through the inside of the building to get from the HDTVi antenna to the DVR/TV.
Then So Be It.
Reason is , Reliable Reception is More Important then objecting to coax running through the inside of the building.
Digital Broadcast DVR Tuners or Digital Broadcast TV Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner , do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
To improve reception and reliability.
Install a , http://www.antennacraft.net , HBU11 , above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East North , East , South East , West.
Aim the , HBU11 , antenna at about , 96 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
No antenna system signal amplifier is required.
For 2 Tv's connected use a , 2 way splitter.
For 3 Tv's connected use a , 3 way splitter.
