Yes can install one antenna on one side of chimney and other antenna on other side of chimney.
You can Test reception with 1 , DB8e antenna.
Aim one of the 4 Bowtie panels at about 10 degrees magnetic compass direction , a in between aim direction for reception of the , North Group and North East group at the Same time.
And aim the other 4 Bowtie panel at about 178 degree magnetic compass direction for reception of the South Group Tv stations.
One antenna with one coax down lead and No A/B switch.
If reception is weak and has drop outs on the weak Tv channels in the Red reception zone of the Tvfool report then install a Channel Master CM7778 preamp.
This one DB8e antenna with panels aimed different directions will most likely work , however I can not say 100% that it will.
A lot depends on avoiding local close trees and other obstructions in the directions of reception.
