Old 18-Dec-2013, 12:53 AM   #10
tfRR
Hey everyone. I really appreciate the help. All the advice worked, except for one main channel (KCPQ) and sadly the main reason I was trying to get this hooked up.
Currently moving the antenna to a higher spot helps tremendously. Removing the pre-amp probably helped to. My question is now.
Should I look into getting a better VHF antenna? I have been reading that the clearstream 4 is not very good for VHF.
I will also be testing the pre-amp this weekend to see if it helps.
I also noticed I cannot get KONG (31) but that isn't as important to me as KCPQ.
Thanks again all!
tfRR is offline   Reply With Quote
