Old 17-Dec-2013, 5:22 PM   #1
abbasteps
Reception - Toronto
here's my graph for my reception:
http://www.tvfool.com/?option=com_wr...46aee4dfea0be9
I just install a ClearStream2™ Complete Long-Range VHF/UHF Digital TV (DTV) Antenna at the roof top balcony. I follow the direction of the graph and point to 168 degree.
I am having issue getting FOX. I can get Fox if I place only at a certain place but if I move it just a little bit the signal will be lost. Would it be fixed if I get an pre-amp, like Channel Master 7778?
Also, I can get ABC and CBS if I place at a totally different location on the balcony and that location is different than where I can get FOX. I don't understand why. From the graph, I should be able to get those 3 channels.
I already cancel my cable, but I would like to get ABC, CBS, FOX and possibly NBC. I know NBC will be difficult because it says so in the graph. But if I get ABC, CBS and FOX, I will be very happy.
Any advice to place the antenna, or should I purchase pre-amp, or my antenna is not good enough?
Any advice will be appreciate.
Thanks
Wilson
abbasteps is offline   Reply With Quote
