Old 15-Dec-2013, 10:59 PM   #10
Home Depot and Lowes , have 10 foot lengths of , Top Rail , fence pipe , the cost of the Top Rail fence pipe is low dollars.
On a Non windy day you can use the Top Rail fence pipe to get the antenna up higher in the air as a Test to see what happens.
If the antenna is installed above the roof of the house , move the antenna away from trees in the direction of reception is a good idea.
And here is a way to use a tall straight tree to get the antenna Up High.
http://www.ronard.com/tree_adjust.html.
The idea is to use a tall straight tree to get the antenna up high for better and less obstructed reception path/s to the transmitter/s.
Cutting away branches for a less obstructed reception and to keep branches from whipping around and breaking the antenna.
Last edited by teleview; 17-Dec-2013 at 7:12 AM. Reason: Clarify information and typos.
