Old 15-Dec-2013, 10:53 PM   #4
Yes the HBU22 is Ok.
You can jump up to a HBU44 , for reception of the , North North West group of Tv stations , however I can not say that WRBJ channel 34 off to the North East will be received reliably , The forward beam width of the HBU44 is much more narrow and reception will be less at a front angles to the HBU44 the further the signal is off to the side of the antenna.
The reception situation using the HBU44 , is a try it and see what happens situation , the antenna aim direction will be some where in between the 2 directions of , North West and North East.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , ronard 712-50-10 , tripod antenna mount.
Use the , ronard (4560) , eave antenna mount.
Measure around the chimney and use a , ronard (2212) , ronard (2218) , ronard (2224) .
Buy the ronard antenna mounts at , http://www.solidsignal.com , or , http://www.ronard.com.
Last edited by teleview; 16-Dec-2013 at 6:53 AM. Reason: Clarify information and typos.
