Old 15-Dec-2013, 7:17 AM   #2
Install a , http://www.antennacraft.net , HBU55 antenna above the Peak of the Roof in such a manner that the Roof and Building are Not , obstructing , impeding , blocking , reception in the directions of , West North , West South , North , North East , East.
Aim the HBU55 antenna at about 296 degree magnetic compass direction.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box , or , buy from , http://www.ronard.com.
Install a , http://www.channelmasterstore.com , CM7778 Preamplifier.
For 2 Tv's connected use a , http://www.hollandelectronics.com , HFS-2D , 2 way splitter.
For 3 Tv's connected use a , http://www.hollandelectronics.com , HFS-3D , 3 way splitter.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv signals bouncing all around.
The Best Practice is to install the HBU55 antenna at a location that has the least amount to no amount obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 18-Dec-2013 at 4:39 AM. Reason: Clarify information and typos.
