Old 14-Dec-2013, 10:54 PM   #2
WBUI , Real UHF channel 22 , virtual number (23.1) , The CW , is very weak signal strength , at minus -5.4 NM(dB) .
Install the DB8 above the roof in such a manner that the roofs and buildings are not , obstructing , impeding , blocking , reception in the directions of , North North West , South South West , East South East.
Aim the DB8 at about 312 degree magnetic compass direction.
WBIU , The CW .
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
For the purpose of the Test of reception have only 1 Tv connected , No splitters.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roofs and buildings.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path reflecting Tv signals bouncing all around.
The Best Practice is to install the antenna at a location and height above ground that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roofs and buildings.
How is reception now??
Last edited by teleview; 15-Dec-2013 at 5:57 PM. Reason: Clarify information and typos.
