Old 14-Dec-2013, 9:56 AM   #2
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception , South East , South , West , North West.
Install a , http://www.antennacraft.net , HBU44 antenna aimed at about 147 degree magnetic compass direction.
Install a , http://www.channelmasterstore.com , CM7778 preamp.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the , HFS-2D , and , HFS-3D , HFS-4D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Here are some strong and sturdy antenna mounts.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
http://www.antennacraft.net.,
http://www.amazon.com.
http://www.solidsignal.com.
http://www.channelmasterstore.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effect are
Absorbing , Blocking , Reception
The Best Practice is the install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 15-Dec-2013 at 6:18 PM. Reason: Clarify information and typos.
